lt80 rear sprocket removal?
Old Jan 4, 2012 | 05:45 PM
Iman's Avatar
Default lt80 rear sprocket removal?
How do I get this sprocket off? Does the axle slide out if I loosen the 2 bolts on the other side? I have the 4 bolts out and the sprocket is over the axle now... The piece that holds the tire on with 3 bolts is welded on
Old Jan 4, 2012 | 07:32 PM
Iman's Avatar
I see now where it is supposed to come off by the piece that bolts up to the wheel but previous owner welded it there. Guess I could grind down the weld. Does anyone know if that axle on that side comes apart?
Old Jan 5, 2012 | 12:19 AM
LT80's Avatar
LT80 Expert
You'll be neding a sawzall/torch and a new axel and hub.
Old Jan 6, 2012 | 03:00 PM
Wildcard0413's Avatar
Thy welded the nut on? Why in the world would they do that?
Old May 6, 2012 | 09:33 PM
rkatekt's Avatar
Out of curiosity, was the nut welded from the factory or did that happy later?
I am curious because I want to change the sprockets on my 89 LT80 and I am not sure how difficult it is? Any help would be appreciated.
Old May 7, 2012 | 08:12 AM
LT80's Avatar
LT80 Expert
NO they are not welded from the factory.
Remove the right rear hub/wheel.
Bratman2
Aug 6, 2022 01:42 AM
Sandman2.0
Jul 21, 2015 09:03 AM
tporath
Jul 11, 2015 12:31 PM
rcappie4
Jul 10, 2015 04:54 PM
Wnthunting
Jul 9, 2015 03:02 PM
