WARN Winch Kit On A Trailer
Old Dec 14, 2012 | 08:18 AM
Q490264's Avatar
Default WARN Winch Kit On A Trailer
I am a long time reader and first time poster and here is my quandary: I have a WARN winch kit 2.5ct Gen 6 Polaris part numbers are: 2874570 and 64891 that I bought for my Magnum and never installed. I want to install it on a trailer and when I hook up the Positive and negative battery cables to my battery the rocker switch will not function. There is a red wire on the switch cable and I am not sure where it goes since it will not go to the wiring harness on my Magnum. Any help would be appreciated.
Old Dec 14, 2012 | 02:36 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to posting on the forum. the wire you ar refering too has to be hooked to a power source to make the rocker switch work. on the atv install, you would hook it to a hot wire that is powerd you turn on the key switch. just remember if you hook this wire up to the battery as well as the red cable that the rocker switch will have power all the time.
Old Dec 14, 2012 | 03:13 PM
Q490264's Avatar
That makes sence. I will run a wire to my ignition switch on my truck.
Old Dec 15, 2012 | 02:32 AM
Ethosb's Avatar
You should also have a solenoid is pack as well.
Old Dec 15, 2012 | 04:29 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sorry, i should mentioned that, but i assumed that he already had that hooked up when he mentioned the power was hooked up "Positive and negative battery cables to my battery" since these are color coded.
Jeff Roper
Feb 1, 2022 11:48 AM
Johnny Mac
60
Dec 14, 2019 06:13 PM
Johnny Mac
Aug 15, 2019 03:13 PM
dannytas
Sep 26, 2017 06:31 PM
badgerboy1
Sep 26, 2017 06:11 PM
