2004 600 Polaris 4x4
Old Jan 14, 2013 | 03:21 PM
grady2012's Avatar
Question 2004 600 Polaris 4x4
Having problem with 4x4 . Works in high with awd switch on or off and dont work in reverse . I press overide button shows on speedo that its on . I change oil from Polaris , no diff .
Thanks
Old Jan 14, 2013 | 04:17 PM
Possibly could be a cracked plastic roll cage in the front differential if it works only in high range regardless if the awd button is on or off. This was a common thing to happen,some wouldn't engage the awd,some would only engage in forward,not in reverse like yours. Plus it could be as simple as an erratic armature plate not releasing. Hard to tell exactly what is wrong unless the differential is removed and taken apart. This is a breakdown of the front differential. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Item #11 is the roll cage,item #26 is the armature plate. If the plastic roll cage is the problem there are aluminum upgraded roll cages from Polaris and some have used John Deere parts. OPT
Jmuddin284
Jan 19, 2026 07:16 AM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
Gtsordo
Jul 13, 2015 10:38 PM
jettman
Jul 6, 2015 12:16 PM
