2004 600 Polaris 4x4
Having problem with 4x4 . Works in high with awd switch on or off and dont work in reverse . I press overide button shows on speedo that its on . I change oil from Polaris , no diff .
Thanks
Thanks
Possibly could be a cracked plastic roll cage in the front differential if it works only in high range regardless if the awd button is on or off. This was a common thing to happen,some wouldn't engage the awd,some would only engage in forward,not in reverse like yours. Plus it could be as simple as an erratic armature plate not releasing. Hard to tell exactly what is wrong unless the differential is removed and taken apart. This is a breakdown of the front differential. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Item #11 is the roll cage,item #26 is the armature plate. If the plastic roll cage is the problem there are aluminum upgraded roll cages from Polaris and some have used John Deere parts. OPT
