03 Prairie 650 heating
Old Feb 8, 2013 | 11:01 AM
johnjjck's Avatar
Default 03 Prairie 650 heating
I am new to the forum and want to say thank you in advance to any help I may get. 03 Prairie 650 overheats and sends half the coolant out the reservoir overflow. I had the heads rebuilt and installed new head gaskets as well as a dyna cdi. I removed all coolant lines and blew air through them to make sure there was no blockage in any line, flushed the system, cleaned radiator, tested the thermostat, and installed a fan switch. I went out last night in 30 degree weather to plow my driveway with fan on and within 20 minutes I had coolant pouring out the overflow and the light flashing hot. I am clueless at this point as to what this could be, any help would be greatly appreciated.
Thanks
John
Old Feb 8, 2013 | 10:39 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Can you tell if water is circlating? water pump working? radiator cap good? Just afew questions thanks for understanding in advance
Old Feb 9, 2013 | 10:58 AM
johnjjck's Avatar
Waterpumpis good, I didnt even think to check the cap though. I will be doing that after work today.
Thanks for the help
Old Feb 11, 2013 | 11:05 AM
johnjjck's Avatar
Thanks papa hogg scoot, I flushed it again filled and burped while standing the front up, and put on a new cap. 2hrs continious running on Sat. never went over 180 degrees, thanks again
Jeff Roper
Feb 1, 2022 11:48 AM
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
Sw00p
Sep 24, 2015 02:50 PM
PrairieDog126
Sep 12, 2015 05:23 PM
