solenoid
Old Mar 25, 2013 | 06:23 PM
timtwig's Avatar
Default solenoid
I have an 09 Sportsman 500 HO that doesn't turn over. The starter and solenoid are both good. The ignition switch works, but the power isn't getting to the solenoid. Please help.
Old Mar 25, 2013 | 06:32 PM
Jaster94's Avatar
replace your inline fuse that should be coming off of the positive cable of the battery which should be >12volts. like 12.6v. amperage on fuse should not be higher than whatever is in there already, not for sure if the fuse is a 5 or 7 amp.
Old Mar 25, 2013 | 06:53 PM
timtwig's Avatar
Default solenoid
I have checked all of the fuses I could find, and all were good. The ignition switch sends out power when the key is turned to start position. The power just isn't making it's way to the solenoid. ???
Old Mar 25, 2013 | 07:40 PM
If the small power wire to the solenoid doesn't have 12 volts,then it's possible you could have a short in the switch wiring or the ignition switch itself. Pull the headlight pod and check out the switch connector and wiring for any shorts/bare wires as this is where most of the twists and turns occur on the wiring.It's not unusual for an ignition switch internal soldered connections to come loose from vibration too. You can also do a continuity test on the red/white wire from the ignition switch connector to the solenoid red/white wire to eliminate it as a problem.
Old Mar 25, 2013 | 08:27 PM
timtwig's Avatar
Default solenoid
I can run a wire from the ignition switch to the solenoid, but then it will start in gear, which could be dangerous.
Old Mar 25, 2013 | 08:58 PM
Jaster94's Avatar
i suppose your neutral switch is working?
Old Mar 25, 2013 | 09:09 PM
timtwig's Avatar
Default solenoid.
I don't know how to properly check the neutral switch, but my guages show which gear I have it in.
Old Mar 26, 2013 | 09:23 AM
Don't run a wire just check continuity on the wire from the switch to the solenoid. This is just a standard check of elimination of problem sources,as most of the time it's either an ignition switch or a bare wire shorting out that needs to be repaired.
Old Mar 27, 2013 | 03:16 PM
timtwig's Avatar
Default Thank You
I finally got the ambition to follow the ignition wire today, and found it broken right under the headlight. Some other wires there needed attention also. It starts with the key, and I didn't even have to buy a part. Thanks for the advice.
Old Mar 27, 2013 | 03:26 PM
This is where they usually break where all the twisting and turning on the harnes is! Glad you got it repaired.
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
EIF
Apr 20, 2017 07:15 PM
Jackg17
Sep 26, 2015 09:30 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
toonces
Sep 5, 2015 01:14 PM
