how much do clutches cost for recon?
Old Mar 26, 2001 | 12:29 AM
98recon's Avatar
I was wondering how much do clutches cost for a recon because i think mine might be goign bad or something because when im taking off it works fine but when i get it in about 3rd gear you can feel it slipin if your givin it full throttle it does this in 4th and 5th to but then it will grap and work just fine hopefully its nothing in my transmission
98 recon stock
Old Mar 26, 2001 | 10:10 AM
gergb's Avatar
First, Try to adjust the clutch as explained in the owners manual. If that does not do it the clutch disk (all 5 disk) cost between $45-$55 from the dealer. I don't know what they charge to put them in as I did it myself.
Old Mar 26, 2001 | 06:46 PM
LotusPosition's Avatar
What did you use for a clutch puller?
Old Mar 26, 2001 | 10:19 PM
gergb's Avatar
Not the $95+ Honda tool for removing the centrifical clutch, I found that a Harmonic Balancer puller I had fit! It looks like a steering wheel puller (with 3 holes) that line right up with the 3 holes in the clutch.
To break the nut free on the clutch pack just put it in 4th or 5th gear and set the parking brake and loosen the nut. You don't need a holding tool this way and you can retorque the nut this way too.
Old Mar 26, 2001 | 11:01 PM
Thanks guy, that some good info. I hope others are paying attention!
Old Mar 26, 2001 | 11:35 PM
Chevelle's Avatar
I recently replaced the clutches in my wifes Recon too. It was acting the same as yours as far as the slipping goes. After the new clutches, it is ok again. The old ones still looked good, but apparently they were the problem. I made my special tools with a big washer and a piece of key stock welded to the washer. It works good.
Old Mar 27, 2001 | 12:05 AM
98recon's Avatar
thanks for the information guys
lonerider856
Oct 13, 2023 03:45 PM
Lou Domenech
Sep 11, 2015 06:35 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Jason Campbell
Sep 7, 2015 02:25 PM
cdstang
Aug 31, 2015 07:52 AM
