97 Prairie 400 "stripping" gears?
Old Aug 22, 2013 | 01:03 PM
Reeder's Avatar
Default 97 Prairie 400 "stripping" gears?
Hey Guys. I'm working on a project 97 Prairie 400. Things are going pretty good! Just got it together and runs strong, but I have a question regarding the bevel gear.
When I get on it, it sounds like it's "stripping" gears. I've heard this can be due to the bevel gear having an incorrect backlash. I didn't have this problem initially. I had to add a 1mm shim to get my belt deflection correct, then it started doing this. It doesn't seem that should affect it though. Any thoughts. Also, When I attached the final drive case to the engine, I used sealant, but no hard gasket. It sealed up great, but do you think the width of that gasket could affect the backlash or mesh of the teeth?
Thanks,
Wayne
Old Aug 22, 2013 | 09:39 PM
MrSummit's Avatar
I would think w/o a gasket the fit would be a little tighter and rather than stripping, it would be a grinding because they are too tight/close. Does it still move when the sound happens or does it feel like a slipping clutch would feel on a normal clutched motorcycle?
Old Aug 23, 2013 | 09:05 AM
Reeder's Avatar
Thanks for the response! Those were my thoughts as well (grinding stripping). When it makes that noise, it is under hard acceleration. It "strips" briefly, like for about a half second, then catches. During that half second it doesn't pull, as if the clutch were pulled in on a dirt bike. So as well as making the noise, something is definitely out of mesh somewhere.
Thanks,
Old Jun 3, 2023 | 07:06 PM
Chadwms8's Avatar
Thanks,
good evening I am having same issue and can't seem to find anything to put me in right direction did you have any luck fixing the problem thanks
JaCkaL829
Mar 17, 2011 11:18 AM
jhawthorne
Oct 19, 2009 01:10 PM
aawhite
Nov 12, 2006 08:18 PM
4chnit1
Nov 15, 2004 04:57 PM
ed700
Sep 17, 2002 09:46 AM
