660 clutch
Old Oct 14, 2013 | 07:12 PM
spits's Avatar
Default 660 clutch
New question about the 660 Grizzly . It's a 2002 and am not sure if the clutch or belt is slipping or if it is normal. When I take off from stop, position the bike seems to rev quite a bit to get it to move, not excessive just higher than I would think maybe normal . Get up to maybe 10-15 kms and the rpms drop and away I go. I am used to a semi-auto where you change gears (98 Big Bear). It supposedly had a new belt when I got it. Any comments appreciated.
Old Oct 16, 2013 | 10:24 AM
TLC's Avatar
TLC
Should take off pretty instantly, does it do it in Low range as well?
Did the guy buy a aftermarket belt?
Old Oct 16, 2013 | 04:34 PM
spits's Avatar
Thanks. I'll check the belt
Old Oct 19, 2013 | 05:36 AM
spits's Avatar
Well finally got around to checking the belt. For a new belt it does have some wear. My manual calls for the width to be 1.310 in. It is at 1.250 so while I have it apart I'll replace it. The other part is that the primary sheave was FULL of heavy grease. the manual says to clean everything in there with a solvent and lightly grease things. It didn't help any when one roller or maybe two were in sideways not letting the sheave open all the way. I'll do a cleanup today, check for damage and hopefully get a ride in this weekend. This is what happens when you buy used off Kijiji.
Old Oct 31, 2013 | 05:29 PM
spits's Avatar
Default clutch update
Well two weeks after I discover the rollers in sideways, I've purchased the centrifical(?) oil bath clutch pack, eight rollers and a new belt. This was on a machine that was taken to the dealer to be checked over before the guy sold it. The dealer said it was ready to go. I also had to put a diaphragm in the carb. I took the clutch drum to work and cleaned up the drive surface. Hopefully I'll have it all back together to ride on Friday.
Old Nov 3, 2013 | 05:52 AM
spits's Avatar
Default Finally
Actually got the bike out for a short ride. Seems to work as it should. Moves with minimal revs and has power all thru the acceleration process. I took it on a strait stretch of smooth pavement and hit 92km( about 55 mph) before I backed off the throttle. Is this typical for approx. top end or does this seem slow(I ran out of smooth road) as there was some throttle left? I don't care about the speed part but it will let me gauge the power level of the bike.
Old Nov 3, 2013 | 10:46 AM
TLC's Avatar
TLC
That sounds right. 55 mph cruise and a top end is 60mph wide open.
I ride with a 660 Grizzly all the time .
My 500 can hit 55 mph also but the 660 can get to that speed in a shorter distance and time.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
