polaris 500 sportsman
Old Nov 22, 2013 | 04:05 AM
jshortbob's Avatar
Smile polaris 500 sportsman
i just aquired a 1999 sportsman 500.previous owner rebuilt carb and broke off one of the tangs that holds the float.looking for used carb for rebuild or main carb body.vin number-4xac450a1xa043768 thanks
Old Nov 22, 2013 | 09:05 AM
If no one on the form has one keep a check on Ebay along with your local Craigslist.Couple on Ebay for 150 bucks,but still pricey. New ones are around $425. If you still have the broken post for this carb you might be able to Jb weld it in place to be able to work. I've repaired a couple like this when people got to aggressive when the punched the float pin out and broke a post.
Old Nov 25, 2013 | 02:52 AM
jshortbob's Avatar
Default polaris
thank you.there is one fairly reasonable now on ebay but it says it fits many models you just change the jets.i am a little concerned if it will work.
Old Nov 25, 2013 | 03:29 AM
I saw this listing for $125 and is a new Mikuni carb and it said it fits the Magnum also if I remember correctly. This carb should fit your model since it should be a BST34 (34mm) http://www.ebay.com/itm/POLARIS-ATV-CARBURATOR-FITS-THE-4-STROKE-ATVs-MIKUNI-CARB-MAGNUM-SPORTSMAN-/390704145810?pt=Motors_ATV_Parts_Accessories&hash=item5af7c82592&vxp=mtr At the bottom of the description does say BST34 Will fit your 98. Heck of a price if it's legit as a new OEM carb on online parts sites is around $400!http://www.cyclepartswarehouse.com/f...1998&fveh=5461
Old Nov 26, 2013 | 04:43 AM
RacerP's Avatar
I bought this carb off eBay for my '02 Xpedition, everything is right with it, figured all the time spent fixing and replacing parts on an old carb...
Gotta think with time and money spent, going to be pretty close to the same amount.
Old Nov 27, 2013 | 02:45 AM
jshortbob's Avatar
Default polaris carb
thanks for the info ------ bob
Jmuddin284
Jan 19, 2026 07:16 AM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
