Kaw. 650 carb. problens.
Old Nov 29, 2013 | 04:41 PM
bodatiouskid's Avatar
Default Kaw. 650 carb. problens.
Have a 2002 Kawasaki Prairie 650 that is popping back through carbs.Just had carbs rebuilt($950) by a Kawasaki mechanic & they are popping back 1/4-1/2 throttle.Mechanic says Kawasaki's do that.Is there something I can tell him to do th fix this problem?I do trail riding & am mostly at 1/2 throttle.
HELP!
Old Nov 29, 2013 | 05:52 PM
tomgodair's Avatar
No offense, but that mechanic ripped you off! 950 is way way over priced. You could rebuild the carbs for like 40 bucks with like an hour of time! That thing should be tuned perfectly and he should know how to do it for 950, otherwise he didnt do his job and I would demand my money back.
Old Nov 29, 2013 | 07:59 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Amen on an rip off....What was atv doing before the carb job?
Old Nov 30, 2013 | 07:59 AM
Thumbs down
Haven't had ATV long.Was popping back through carbs,so took to a friend to clean them.Still popped back,so stupid me ran straight Seafoam in tank & let sit overnight.RAN WORSE!.
So,took to Kawasaki dealer to fix problem.After a month I get ATV back with a bill of $950.($575 in parts includes battery)
Now has gone back to how it was running when I bought it.Popping back through carb at 1/4-1/2 throttle & maybe higher.I trail ride & hunt & that's the RPM I mostly use.
The mechanic says that's normal on these models.That looks bad on Kawasaki.Who'se gonna buy an ATV that runs like that?
Old Nov 30, 2013 | 11:10 AM
Zrock's Avatar
Super Quad Patrol
gezz what parts did he change? and did they call you or have you sign for the extra work?
Old Dec 7, 2013 | 12:43 AM
Hayashi's Avatar
HELP!
Your carbs are running too lean at the mid-range.
There are 2 fuel screws on the twin carbs which are capped off with epoxy like material (or aluminum plug) from the factory. Remove the cap using a drill bit w/o damaging the screw. Then turn CW slowly and gently until it bottoms out/stops. Then turn CCW about 2 and 1/2 turns and stop on BOTH fuel screws.
Old Dec 7, 2013 | 03:08 PM
I called Kawasaki.GET THIS:Kawasaki says it is normal what my ATV is doing.Says it is how they built the carbs.
Just had them rebuilt by a Kawasaki dealer.
Old Dec 9, 2013 | 01:44 PM
Hayashi's Avatar
Manufacturers and (some) dealers don't want to mess with the EPA related parts - that's OK only if the machine is running correctly. It's not in your case. Sometimes you have to take it in your own hands.
Old Dec 9, 2013 | 03:57 PM
Guess I need to find a mechanic that doesn't work for Kawasaki.
I have to say,what they told me makes no sense.What good is an ATV if you can't run it slow without the motor popping?Have sent dealer a letter saying am VERY upset of how ATV is running.Says right on work order"GET RUNNING CORRECT"
Old Dec 9, 2013 | 05:42 PM
Loved
Community Favorite
Is atv belt light on?
