450 foreman stator
Old Dec 16, 2013 | 08:53 PM
200es's Avatar
Default 450 foreman stator
i have a 2002 450 foreman, i recently put heated grips and thumb warmer on it. but now it seems to be to much draw on the electricle system and i keep losing 4x4. is there a higher out put stator i can buy? my battery is a new motomaster eliminator
Old Dec 18, 2013 | 02:08 PM
The alternator should be able to cope with heated grips, they take less power than the lights. Did you wire them through the ignition? If not it is all to easy to leave them switched on overnight which will run the battery down, and a quad battery will be ruined if left flat for a few days.
If you can get a 30 amp ammeter, check if the grips are taking more power than the alternator is putting out with the engine reving above tickover. If they are, either the alternator or regulator is faulty.
ultangler
Nov 30, 2024 01:35 AM
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
