2003 Polaris sportsman 700 ignition no start
Old Jan 30, 2014 | 03:25 PM
Dsalmons's Avatar
Default 2003 Polaris sportsman 700 ignition no start
Polaris # EH0680LE011
2003 sportsman 700
I have no spark on either cylinder
I have read some of the posts about the Ducati ignition system and the change over kit 2202602 just wanted to make sure this was correct part number before I ordered it
Also is there anything to watch for when doing this kit I have flywheel puller and also a good commercial solder iron for stator connections.
Old Jan 30, 2014 | 05:21 PM
Correct part#. Shouldn't need the soldering iron as all stator wiring and jumper harnesses have connectors. Seems like the most common complaints were not grounding the stator brown(ground) wire securely plus the extra red wire needed to tie into the jumper harness is buried deep in the main harness and you have to dig for it. Here's the pdf basic kit parts list and instructions. http://www.google.com/url?sa=t&rct=j...,d.aWc&cad=rja
Old Jan 30, 2014 | 07:09 PM
Big600twin's Avatar
Welcome to the forum and good luck You will be happy with how much better the machine will run.... just sucks that the cost of parts is so high...
Old Jan 31, 2014 | 02:35 PM
Dsalmons's Avatar
Thanks, I appreciate people like you guys that spend your time helping out with info and advise.
whitty
67
Feb 24, 2021 02:52 PM
neilbedwell
Nov 10, 2018 11:02 AM
Thanos
Jul 12, 2015 08:40 PM
May 27, 2015 11:15 AM
