scram gears/sand
Old Apr 4, 2001 | 10:47 AM
SPANKY500's Avatar
I plan on riding some dunes, ive got a 01' scram 500 4x4 would it be benificial to change gearing to help manage the sand. I dont plan on using 4 wheel drive but if i should happen to need it how bad will the different gearing screw it up? even different size tires would alter the 4x4 right. maybe more or less paddles. what would be the best combo to make this machine run good in sand.
spanky500
01' scram 500 4x4
98' yz 250
Old Apr 4, 2001 | 06:13 PM
WyoRider's Avatar
Hey, Spanky I see you are in Colorado. What sand dunes are you planning to go to and when. Chances are I've been there as well as a lot of others in the CO area.
Old Apr 4, 2001 | 09:48 PM
SPANKY500's Avatar
HEY WYORIDER
I CANT CALL THEM DUNES JUST THE HILLS IN WALDEN. IVE BEEN TO YOUR SITE AND COMMENTED ON IT, IN ANOTHER POST OF YOURS. IF I GET ENOUGH TIME OFF I PLAN ON GOING TO ROCK SPRINGS. IVE BEEN TO WALDEN A COUPLE OF TIMES AND ENJOYED IT SO I PLAN ON TAKING THE WIFE AND KID WHO IS TOO YOUNG TO DO TO MUCH WITH RIGHT NOW BACK UP THERE THIS SUMMER A COUPLE OF TIMES. I WAS ALSO UP AT PAWNEE LAST WEEKEND ALOT OF FUN BUT IT WAS GETTING PACKED
SPANKY500
01' SCRAM 500 4X4
98' YZ 250
Old Apr 6, 2001 | 10:18 PM
SPANKY500's Avatar
ALRIGHT HOW ABOUT JUST CHANGING THE STOCK SPROCKETS FOR ANY REASON. HAS ANYONE DONE IT ON THE SCRAM 500 4X4. MAYBE TO MANAGE MUD FOR EXAMPLE. MAYBE MY THOUGHTS ARE ALL WRONG AND ITS THE PERFECT MACHINE FOR ANYTHING AND EVERYTHING. THERE HAS TO BE A REASON FOR RE-GEARING IF ITS DONE ON SO MANY OTHER MACHINES? I GUESS ILL STOP RAMBLIN' ON FOR NOW.
SPANKY500
01' SCRAM 500 4X4
98' YZ 250
Old Apr 6, 2001 | 10:39 PM
Xplor's Avatar
Different gearing or changing sprocket sizes can screw up the 4x4 system. Maybe a good aftermarket clutch kit will make your power get to the ground better. You can call HPD or RCR and get some advise. Different helix angles, weights or springs all have different affects on power transfer to the wheels. There must be a great set-up for sand.
Old Apr 8, 2001 | 10:43 PM
Rainman's Avatar
I have just returned from Silver Lake with my stock 01 500 4x4. I wish I was a more agressive rider, but I did climb Jeep/Test Hill, and the other tall dunes(I am afraid of heights).
I had no troubles(other than rear brakes wearing out), and the performance was fine. The CVT performed great, and I have to keep coignizant that it's in the proper ratio whatever the engine sounds like. I had fun in the drag races, even though I was always last.
Rainman
MarkN
Feb 3, 2001 09:56 PM
jim
Jan 29, 2001 09:54 AM
ox
Jan 21, 2001 12:57 PM
spyder30
Dec 28, 2000 06:38 AM
ScramHO
Dec 23, 2000 06:30 PM
