425 Magnum running problems
Old Sep 20, 1999 | 11:15 PM
colonel's Avatar
I have a 1995 Magnum. I have had it to the shop and had the carb rebuilt and valves adjusted, but it had never ran right. When you are barely giving it throttle it seems to be missing. As you speed up it is fine. I also had a friend rebuild the carb, but it still does the same. Any ideas out there??
Old Sep 24, 1999 | 08:09 PM
corncob2's Avatar
Had to go get my book remembered reading about such problems.Try the speed limiter system,My book says it will cause misses.
TEST PROCEDURE
when problems occur that sound like spark-related"miss",the speed limiter sys. maybe at fault.DIsconnect the black wireat the limiter module.If problem still exist not limiter.One more ENGINE MISS AT IDLE_(ETC switch adjusted incorrectly) One more thing when carb rebuilt did he change needle they had problems with them,were made of to soft metal.If can help anymore let me know have manual can e-mail pics,or text.
[This message has been edited by corncob2 (edited 09-24-1999).]
Old Sep 24, 1999 | 09:30 PM
Kagey's Avatar
Check the throttle cable free play , It has a system which will kill the engine in the event of a stuck throttle. I have seen stretched cables make engine do some strange running.
Kevin Gowdy aka Kagey 1999 Polaris Magnum 500
Old Oct 8, 2003 | 05:06 PM
KW's Avatar
KW
Default 425 Magnum running problems
Did you ever resolve this issue? My 95 does exactly the same thing.
Old Jan 5, 2007 | 09:08 AM
polarbare21's Avatar
Mine also does this, What parts should I order for the carb? And did you get yours running right?
green giant
Jul 13, 2017 12:07 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
Nowinsky94
Technical and How-To Articles
May 27, 2015 07:29 PM
Dave8888
May 2, 2001 06:55 AM
