Front drive drain plug washer
Old Apr 8, 2015 | 09:35 AM
bthrel's Avatar
Default Front drive drain plug washer
Hey folks, (second post after introducing myself… great forum)
Anyone source a replacement washer for the front drive oil drain plug (centralized hillard clutch housing). Polaris parts manual lists it as this --- Asm., Drain Plug (Incl. Plug and Washer) - 3233951.
partzilla and others want over $20 for the plug and washer ….
Its for a 2004.5 Sportsman 500 HO… I'm a OCD type person when it involves fluid change and like to replace the washer/seals when changing fluids.
Thanks
Brian
Old Apr 8, 2015 | 09:41 AM
It's just a plain old teflon type washer that you can just match up at any auto or good hardware store.http://www.ebay.com/itm/NEW-OEM-Polaris-Drain-Plug-Sportsman-Magnum-Ranger-ATP-UTV-3233951-NOS-/251365319135?hash=item3a868a61df&vxp=mtr
Old Apr 8, 2015 | 09:46 AM
bthrel's Avatar
OPT .. thank you sir .. I was betting you would be the first to reply, your wreath of knowledge of all things polaris is amazing ..
Anyway, I did order a new plug assembly so I could take the washer around and compare it .. so far no joy at TSC, Lowes, Depot, Ace, Oreillys, Autozone.
Go figure, guess I need to keep searching .. strange that polaris does not sell it separately.
Thanks again
Brian
Old Apr 8, 2015 | 10:14 AM
If you have some calipers you can measure the inside and out side diameter and order by the package for future use.10pcs New PTFE Teflon Washer Gasket 8 12 2mm | eBay If you had an Elliots hardware stores like we have down here they would have them or would get them for you.. They put Ace to shame on what all they carry.
Old Apr 8, 2015 | 10:58 AM
bthrel's Avatar
Thank you again .. by my measurements its 16mmx10mmx2mm (outside, inside, thickness) .. I will check the link and see what they have close.
Cheers
Brian
jayking232003
Dec 4, 2019 09:38 AM
WilliamBos
Sep 30, 2015 08:08 AM
DOAinNY
Jun 12, 2015 02:26 PM
DOAinNY
Jun 11, 2015 10:34 PM
hoopduerr
Jun 2, 2015 09:01 AM
