Oil in Starter
Old Sep 26, 1999 | 06:51 PM
Andy_G's Avatar
I was changing all of the fluids in my 400 Xplorer today and while I was down there I removed the drain screw from the starter. When I took it out about 3 table spoons of oil came out. I thought that screw was just to drain any water that might seep in. Do I need to replace this oil somehow.
Thanks
Andy G 98 400 Xplorer
Old Sep 26, 1999 | 11:11 PM
xpoltech's Avatar
Are you sure that plug was the starter drain?
The reason I ask is that there is a drain plug(for the counter bal. shaft) very very close to the starter drain it(the counter bal. area) will only hold 75-100 cc of oil(depending on the year)
DO NOT RIDE IT WITHOUT THE COUNTER BAL. OIL!!!!
Old Sep 26, 1999 | 11:25 PM
Andy_G's Avatar
This drain was on the starter itself right below where the bendix drive gear would be. I did drain the counter balance oil and replaced it so that is ok.
Andy G
Old Sep 27, 1999 | 09:49 PM
MikePopson's Avatar
I had the same problem on my Scrambler 400. The counterbalance oil leaked out of the crank seal behind the stator.
Old Sep 28, 1999 | 01:03 PM
Loyal's Avatar
Has anone else had the problem of the starter freezing during the winter. Even when I drain the water out of the starter it still freezes. What I have done for the past two winters is spray Rust Check (in the green can) up into the starter after I drain the water. The Rust Check displaces the water and sticks to the inside of the starter "gears". The freezing is less frequent now.
Loyal
Johnny Mac
Aug 15, 2019 03:13 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
wrencher82
Sep 28, 2015 10:02 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
