Lt160 transmission issue.
Old Jul 1, 2015 | 01:17 PM
bikedad3's Avatar
Wink Lt160 transmission issue.
Working on a 1989 Suzuki Lt160 quadrunner. I replaced everything in the transmission and it was in neutral when I put the engine back together. Mounted engine in frame and now motor is stuck in reverse. Any Ideas?
Thanks
Old Jul 1, 2015 | 07:19 PM
rotaxtwin's Avatar
The only thing I can think of is the reverse shift shaft is in the wrong position inside the transmission. Did you try to turn the counter shaft sprocket before putting the motor back into the frame.
Old Jul 2, 2015 | 02:15 AM
I don't know the LT160 but if it has a cable/rod operated linkage like most Suzukis, have you got the external lever on the side of the box on the right spline?
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
shimanok2
Jan 29, 2016 07:37 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
