2006 arctic cat 400 4x4
I bought an 06 arctic cat 400 4x4. I put in a carb kit. Idles fine and will take throttle when cold. After 5 minutes of riding. It will idle but dies when you give it throttle. The guy said he replaced the flywheel and cdi. The coil looks to be old. Help!
The slide in the carb is not coming up. After a few minutes of running. It will operate right if i manually raise it a few times it. Then it will do it again. Float problem? Has electric choke
Sounds to me like you need to revisit your carb cleaning/rebuild. The slide should always move freely when moving it by hand.
Norway1
May 8, 2016 05:54 PM
