2006 arctic cat 400 4x4
Old May 12, 2016 | 04:59 PM
Angryarcticcat's Avatar
Default 2006 arctic cat 400 4x4
I bought an 06 arctic cat 400 4x4. I put in a carb kit. Idles fine and will take throttle when cold. After 5 minutes of riding. It will idle but dies when you give it throttle. The guy said he replaced the flywheel and cdi. The coil looks to be old. Help!
Old May 16, 2016 | 01:09 PM
Zrock's Avatar
Super Quad Patrol
Sounds like your carb needs some fine tuning. What kind of choke? If its electric it may not be coming off all the way
Old Jun 5, 2016 | 11:49 AM
The slide in the carb is not coming up. After a few minutes of running. It will operate right if i manually raise it a few times it. Then it will do it again. Float problem? Has electric choke
Old Jun 5, 2016 | 12:37 PM
Fasteratv's Avatar
Sounds to me like you need to revisit your carb cleaning/rebuild. The slide should always move freely when moving it by hand.
DoBoY
Aug 28, 2017 07:52 AM
Angryarcticcat
May 20, 2016 10:16 AM
ctxkiger
May 17, 2016 08:39 AM
Adiredneck
Sport Quads
May 12, 2016 09:43 PM
