sportsman does not display Neutral - only occasional
Old Jun 21, 2016 | 08:59 AM
thippe's Avatar
Default sportsman does not display Neutral - only occasional
2009 sportsman 800...my newest issue is that I have code 25, and maybe once or twice while out riding the shifter does not display Neutral on the dash when i shift into it. i have only noticed the problem with neutral. I checked the gear circuit diagnostics and the voltage all looked ok. Neutral came up as 160, 158 is normal. But i was thinking maybe since its not a problem all the time i would have to keep checking it in there for awhile until it actually shows up.
I cleaned and applied dielectric grease to the switch rotary plug with no difference. Is it safe to say the switch rotary is bad? It seems like its ok to let it get a little more consistently worse before buying the new part. $90 for that little thing....nothing is cheap on these things, lol
Old Jun 21, 2016 | 09:22 AM
60 bucks here. Item#25. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Does sound like the rotary switch and I've replaced a bunch of them over the years for this same thing. Double check everything,but sounds like you have for the most part.
Old Jun 21, 2016 | 10:42 AM
thippe's Avatar
ok thanks!
Old Sep 11, 2016 | 01:50 AM
Guido78's Avatar
My trx90 is doing the same thing. Neutral light might come on might not. So I replaced it now it's doing the same thing. Could it be a loose wire or something else?
Old Sep 11, 2016 | 07:00 AM
You can get better help posting in the Honda section,but remove the connector and clean and see if that helps.Item#6 in the picture. Here's a free pdf manual that might come in use for this and other problems.http://www.mediafire.com/download/8y...ice+Manual.pdf
Attached Thumbnails sportsman does not display Neutral - only occasional-14hp2601_hp24e1000.gif
Kazjag500
Feb 18, 2016 03:09 PM
Matthew30
Jan 27, 2016 07:14 PM
machias
Jun 13, 2000 11:04 PM
JRM
Nov 19, 1999 01:41 PM
