Help with 1993 Timberwolf no start
It will not start by pushing the button. If I jump the solenoid it will start and neutral light comes on. When I shut it off no light. It will not restart. I replaced the solenoid and no luck. If I ground out the wire to negative on battery no light. Could it be a bad ignition switch? Mine has been replaced and no connector, hard wired key switch. Need help. What am I missing to start this?
On most quads the ignition switch is two switches combined, a switch for the battery positive, this feeds starter, lights horn etc, and a kill switch to negative, for the ignition, that is why most switches have four wires going to them. Get the correct switch for your model and wire it in properly.
60studehawk
Jan 18, 2016 11:07 AM
jmelton
Ask the Editor
Jan 7, 2016 06:58 PM
MaxAZ
25
Aug 30, 2000 10:40 PM
