Help with 1993 Timberwolf no start
Old Jul 25, 2016 | 09:36 PM
sefh3's Avatar
Default Help with 1993 Timberwolf no start
It will not start by pushing the button. If I jump the solenoid it will start and neutral light comes on. When I shut it off no light. It will not restart. I replaced the solenoid and no luck. If I ground out the wire to negative on battery no light. Could it be a bad ignition switch? Mine has been replaced and no connector, hard wired key switch. Need help. What am I missing to start this?
Old Jul 26, 2016 | 10:33 PM
sefh3's Avatar
Is there a way to test the ignition switch?
Old Jul 28, 2016 | 09:46 PM
sefh3's Avatar
Well tonight I was able to start the quad by jumping the solenoid. While running I could turn the switch off and pull the key out and it still ran. I think my switch is stuck open.
Old Jul 29, 2016 | 02:51 AM
On most quads the ignition switch is two switches combined, a switch for the battery positive, this feeds starter, lights horn etc, and a kill switch to negative, for the ignition, that is why most switches have four wires going to them. Get the correct switch for your model and wire it in properly.
Zephead98
Apr 10, 2016 11:08 AM
60studehawk
Jan 18, 2016 11:07 AM
jmelton
Ask the Editor
Jan 7, 2016 06:58 PM
Blodg500RX
Oct 17, 2002 01:33 AM
MaxAZ
25
Aug 30, 2000 10:40 PM
