Big bear front bearing replace
Old Aug 22, 2016 | 02:20 PM
Tla316's Avatar
Default Big bear front bearing replace
I am trying to replace front bearings on big bear 350 but can't get the hub off to get to the bearings. How do I get it off?
Old Aug 23, 2016 | 12:13 PM
Tla316's Avatar
Default Front bearings on big bear 350
I am really needing help can not get things separated so I can get to bearings any ideas or suggestions?
Old Aug 23, 2016 | 04:01 PM
It may depend on the age of your Big Bear and will depend if it is 2WD or 4WD. The only Yam front hubs I have changed had a nut holding the disc and hub onto the drive shaft. Remove caliper, remove nut, pull hub and disc off, remove track rod end, remove pinch bolts for top & bottom ball joints and knock joints out of knuckle assembly. Once knuckle assy is off, move the spacer between the two bearings over slightly so you can knock one bearing out with a drift through the centre of the other bearing, then remove spacer and knock other bearing out.
Old Aug 23, 2016 | 04:18 PM
Tla316's Avatar
Default Got them off
Finally got a 3 point puller to get it off. I will do the same tomorrow they are really bad. Rode it but still having a noise on the front seems like I need to greese up something. Hoping that maybe tomorrow once I pull the other on it will go away.
Old May 25, 2017 | 03:45 PM
Dave1's Avatar
Trapper Dave
Default Bearing Failure??
This is an old thread but did you find and cure the front noise issue?
If not, jack up the front end and spin each wheel and listen for and feel for any noise, metal grating, wheel wobbling, etc. If wheel bearings seem to be OK, bounch the front end up and down and listen for a lower ball joint creaking. I have that problem now.
Dave
Old Oct 1, 2023 | 10:23 AM
Bodine88w's Avatar
Default 1996 yamaha big bear 350 4x4 hub
Does anyone know if I can use a rear hub on the front. I have been looking can't find an answer for my question. They only difference I can tell is there is a hole in the front hubs and the rear one is sold.
Old Oct 2, 2023 | 02:57 AM
According to Babbitts parts book, the bearings and seals have different part numbers so are probably a different size. Only way to check is put drums side by side and measure drum dia and sizes of bearing and seal spigots. Spline sizes too may differ.
Lochlin
Aug 23, 2016 11:37 AM
Joe Davis
Aug 15, 2016 02:07 AM
CrazyQuickDraw
Aug 12, 2016 10:49 AM
mtnxtreme
Aug 11, 2016 11:53 AM
bodatiouskid
Aug 9, 2016 01:36 AM
