Ive tried everything 110cc will not fire
Old Sep 19, 2016 | 08:10 PM
Lynnard's Avatar
Default Ive tried everything 110cc will not fire
I started trying to get this atv to run and it ran fine except the battery would die within 15 mins. Trouble shot this and found out voltage regulator was bad. Next I found the remote control by the back axle and didn't know that's what it was at first and grounded the sensor wire and after that it would not fire. I ungrounded the sensor wire and purchased a new cdi, a new voltage regulator, a new coil, and cleaned the carb. I checked the ground and it seemed fine the safety kill switch in the rear the wires have been cut and the toggle switch on handle bars seems to be working ok. I have voltage coming from stator as it turns over. But will not fire I also got a new plug. Any help with this is greatly appreciated im about to pull my hair out.
Old Sep 20, 2016 | 03:25 PM
DirtDevil101's Avatar
Do you have spark? I'm hoping so after all the electronics purchased/replaced...
Old Sep 20, 2016 | 03:28 PM
Lynnard's Avatar
No Sir I still don't have a spark I'm all out of ideas to try on this thing I'm missing something I know just not sure where to start
Old Sep 21, 2016 | 08:56 AM
Zrock's Avatar
Super Quad Patrol
try hooking the rear tether wires that you cut together. Depending on the switch they are ether normally open or normally closed. You may have fried that remote control box by grounding the antenna. Try unplugging that box
Old Sep 21, 2016 | 04:19 PM
Lynnard's Avatar
I do remember when it had fire that back tether wires were not hooked together but I did unplug remote box and took black and white wire loose from cdi still no fire. I checked voltage out of stator and it was only like .23volts could be my stator.
Old Sep 22, 2016 | 12:28 PM
yup...but you would know that because you'd have a very weak spark at the plug...
Old Sep 22, 2016 | 12:32 PM
Lynnard's Avatar
Yeap I thought I did see a weak spark every once in awhile so I just ordered me a stator hopefully that fixes it my 9 yr old is driving me more crazy than atv is.
Old Sep 22, 2016 | 01:17 PM
LOL...I feel your pain...
Old Sep 23, 2016 | 09:23 AM
Zrock's Avatar
Super Quad Patrol
hopefully the new stator fixes it.. I went through on the one im working on and cleaned all the grounding points including the coil mount, also replaced the battery terminals and got my good strong spark back
Sonnyday
1) Engine problems..
Aug 18, 2016 02:23 PM
Whitetailhunter8955
Jul 30, 2016 01:22 PM
JoshuaMichael
Jul 22, 2016 09:58 PM
Notty1975
Technical and How-To Articles
Jul 8, 2016 05:06 AM
Notty1975
Jul 7, 2016 03:57 PM
