2005 Polaris 500 ATP
2005 Polaris 500 ATP Electric start doesnt work
I am looking at buying this machine but it has a problem the key ignition will not start it guy says the battery is good but you can start it with the pull rope very easy any idea what cause this I also noticed the head light does not come on don't know if the problem is related or not
2005 models had the ecm module problem. That could be why you can't start it with the electric starter.OR the starter could be out. You can pull start one,but IF the ecm is faulty,it could cut power to the dash,electric starter,lights,fan,charging system,etc. All the circuit breakers and a lot of controls are in this one box. There was a recall that changed the black Chinese modules to the silver US made modules but these can and have failed also. If it still has the black Chinese one,it can be replaced free of charge. http://www.cpsc.gov/en/Recalls/2008/...o-Fire-Hazard/ If it's already been changed,the next one is on the owner. If the machine runs good,looks good,been taken care of,a faulty ecm or starter isn't necessarily a deal breaker imo.2004-2006 POLARIS Sportsman 450 500 Scrambler OEM Surepower ECM PDM 2203348 | eBay Here's what Kbb shows. You can use it as a basic guide to deal with the owner if you're interested in it.https://www.kbb.com/motorcycles/pola...-500-4x4/2005/
Just saw it was the Atp you're looking at and it used a different more expensive ecm IF that's the problem.http://www.partzilla.com/parts/detai...P-2203130.html That you may want to deal a little closer on with the owner. Make him aware that you know possibly what could be the problem and how much money it could take to repair.. Good luck on whether you decide to pursue this one or walk away.. Plus the Atp 500 showed the same on value as the Sportsman 500.
no I have no checked the Head Light bulb yes the instrument cluster does light up when key is in the on position. Will it hurt to run the machine temporarily with an ECM being out and is there any way to test this ECM to assure that is the problem before spending that kind of money. The machine only has 185 hrs on it and has been kept in a garage its entire life. I realize I need to check the battery and terminals first but I figured after pull starting it the head light would work. The Current owner did mention that he had issues with the ignition switch when he was using it not wanting to start every time could this be tied into all this issues. How is the best way to check this items for faults?
With the key on IF you're getting power to the dash then at least one function of the ecm is working and maybe all it's functions. The problem again could be a faulty ignition switch,starter solenoid,starter or simply a dead or discharged battery causing all of the above. Switches,solenoids and even starters are cheap if needed also. You can check the charging function of the ecm by just checking battery voltage at an idle after you pull start it. Should be 14+ volts in most cases if the ecm is working correctly.
Polsrid atp 500 won't stay running
Ok I got it home remember we pull started it and it ran two weeks ago. I have cleaned fuel tank and lines cause it was starving for fuel put fresh fuel in it put jumper cables on it and it started right up with the key everything seems to be working just fine. When I go to take jumper cables off it dies and everything goes dead. Is it just the battery or is there another possible issue ? I assume it would be just like a car after jumping it off if the charging system is operating correctly it would run even with a bad battery. And yes I know the battery is bad.
