2005 Sportsman 700 rear differential
Old Dec 3, 2017 | 08:03 PM
TwitchBarfield's Avatar
TwitchBarfield
Thumbs up 2005 Polaris Sportsman 700 Rear Differential
I have a 2005 Polaris Sportsman 700 (Non EFI, not sure if that makes a difference) and my rear differential took a dump on me. What all years/sizes share this same differential as mine? I have found a 2002 Sportsman 500 and just curious if the rear differential out of it is the same. Thanks everyone.
Last edited by TwitchBarfield; Dec 3, 2017 at 08:12 PM. Reason: Supplying more details
Old Dec 3, 2017 | 08:23 PM
Sportsman 500 is different as the diff is incorporated in the transmission. Yours has a separate rear diff and gear case. Several models show to use the same rear diff.
Usage : 1332366
Year Product Model Assembly
2008 ATV SPORTSMAN 800 EFI SCANDINAVIAN DRIVE TRAIN, REAR GEARCASE INTERNALS (Built 1/31/08 and Before) - A08MH76SS/SF (4999200299920029D04)
2008 ATV SPORTSMAN 800 HO EFI DRIVE TRAIN, REAR GEARCASE INTERNALS (Built 1/31/08 and Before) - A08MN76AF/AL/AQ/AR/AS/AT/AX (4999200299920029D04)
2007 ATV SPORTSMAN 700 EFI GEARCASE, REAR - A07MH68AX/AY/AZ (4999200229920022D03)
2007 ATV SPORTSMAN 800 EFI GEARCASE, REAR - A07MH76AL/AQ/AX/AY/AZ/A2/MN76AF/AT/AY (4999200299920029D04)
2007 ATV SPORTSMAN 800 EFI INTL GEARCASE, REAR - A07MH76FA (4999200299920029D04)
2006 ATV SPORTSMAN 700 GEARCASE, REAR - A06MH68AA/AD/AF (4994229422D05)
2006 ATV SPORTSMAN 700 EFI GEARCASE, REAR - A06MH68AQ/AT/AX/AY/AZ (4994229422D05)
2006 ATV SPORTSMAN 800 EFI GEARCASE, REAR - A06MH76AL/AQ/AT/AX/AY/AZ (4994229422D05)
2005 ATV SPORTSMAN 800 EFI GEARCASE, REAR - A05MH76AC/AT/AU/AW (4994229422D05)
2005 ATV SPORTSMAN 600 REAR GEARCASE - A05MH59AK/AN (4994229422D05)
2005 ATV SPORTSMAN 700 EFI REAR GEARCASE - A05MH68AC/AS/AT/AU/AW (4994229422D05)
2005 ATV SPORTSMAN 700 REAR GEARCASE - A05MH68AK/AN/AD (4994229422D05)
Old Dec 3, 2017 | 08:26 PM
TwitchBarfield
Thumbs up
Usage : 1332366
Thank you sir! Very much needed info.
Old Dec 4, 2017 | 02:12 PM
TwitchBarfield
Located a rear differential out of a Sportsman that’s the generation right before mine. Square headlights style. The rear differential looks identical to the one in my 2005. Will it work? Guy told me he thinks it is 2” shorter. Any info is greatly appreciated!
Old Dec 4, 2017 | 04:18 PM
Look at your other post on this.. You don't have to post twice on the same subject.
Old Dec 4, 2017 | 08:00 PM
TwitchBarfield
I gotcha. I will keep that in mind, sorry. Thanks again for the great info on the other post!
Powerranger262
Sep 13, 2020 07:22 AM
cornermike
Feb 20, 2018 02:35 AM
lph008
Nov 30, 2017 05:39 PM
dhwilcox
Nov 7, 2017 02:57 PM
Whitetailhunter8955
Oct 14, 2017 02:36 PM
