2005 Sportsman 700 rear differential
2005 Polaris Sportsman 700 Rear Differential
I have a 2005 Polaris Sportsman 700 (Non EFI, not sure if that makes a difference) and my rear differential took a dump on me. What all years/sizes share this same differential as mine? I have found a 2002 Sportsman 500 and just curious if the rear differential out of it is the same. Thanks everyone.
Last edited by TwitchBarfield; 12-03-2017 at 08:12 PM. Reason: Supplying more details
Sportsman 500 is different as the diff is incorporated in the transmission. Yours has a separate rear diff and gear case. Several models show to use the same rear diff.
Usage : 1332366
Year Product Model Assembly
2008 ATV SPORTSMAN 800 EFI SCANDINAVIAN DRIVE TRAIN, REAR GEARCASE INTERNALS (Built 1/31/08 and Before) - A08MH76SS/SF (4999200299920029D04)
2008 ATV SPORTSMAN 800 HO EFI DRIVE TRAIN, REAR GEARCASE INTERNALS (Built 1/31/08 and Before) - A08MN76AF/AL/AQ/AR/AS/AT/AX (4999200299920029D04)
2007 ATV SPORTSMAN 700 EFI GEARCASE, REAR - A07MH68AX/AY/AZ (4999200229920022D03)
2007 ATV SPORTSMAN 800 EFI GEARCASE, REAR - A07MH76AL/AQ/AX/AY/AZ/A2/MN76AF/AT/AY (4999200299920029D04)
2007 ATV SPORTSMAN 800 EFI INTL GEARCASE, REAR - A07MH76FA (4999200299920029D04)
2006 ATV SPORTSMAN 700 GEARCASE, REAR - A06MH68AA/AD/AF (4994229422D05)
2006 ATV SPORTSMAN 700 EFI GEARCASE, REAR - A06MH68AQ/AT/AX/AY/AZ (4994229422D05)
2006 ATV SPORTSMAN 800 EFI GEARCASE, REAR - A06MH76AL/AQ/AT/AX/AY/AZ (4994229422D05)
2005 ATV SPORTSMAN 800 EFI GEARCASE, REAR - A05MH76AC/AT/AU/AW (4994229422D05)
2005 ATV SPORTSMAN 600 REAR GEARCASE - A05MH59AK/AN (4994229422D05)
2005 ATV SPORTSMAN 700 EFI REAR GEARCASE - A05MH68AC/AS/AT/AU/AW (4994229422D05)
2005 ATV SPORTSMAN 700 REAR GEARCASE - A05MH68AK/AN/AD (4994229422D05)
Usage : 1332366
Usage : 1332366
Usage : 1332366
Whitetailhunter8955
10-14-2017 02:36 PM
