Starts, but when you run it, it shuts off at a random times.
Old Dec 27, 2017 | 07:32 AM
Thomask155's Avatar
Thumbs up Starts, but when you run it, it shuts off at a random times.
My Kawasaki Bayou 300 1998, has been acting up since we bought it. Finally we couldn't fix it on our own so we took it to a guy he fixed it. Recently I was riding it and all of a sudden it shuts off half speed down a hill. Long story it has been sitting in my garage since this fall, and I am tired of seeing it collecting dust. It's start up with one click from the electric start or a couple pulls from the pull start. I had it idlesing at least 5 minutes without touching the throttle. But when I put it into gear it will only go a quarter of a mile till it shut off agian. Also when it shut off wait a little while then it will start back up. Full of gas. I have had no ideas. Thanks
Old Dec 27, 2017 | 08:22 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
Could be something as simple as the gas cap vent line being pinched. I'd start there.
Old Dec 27, 2017 | 08:42 AM
Thomask155's Avatar
Thanks, I will try that first
Old Dec 28, 2017 | 08:08 AM
LT80's Avatar
LT80 Expert
Did you clean the carb?
Old Dec 28, 2017 | 08:37 AM
Thomask155's Avatar
Ya about a year ago, but I should probably do that too
Old Dec 28, 2017 | 06:44 PM
Kymco 450i's Avatar
Don't just clean the carb do a complete rebuild with a proper kit so all adjustments are correct and all new gaskets. Be sure to blow out all orfices and run a fine wire thru them. Just a simple cleaning can cause more problems than it fixes. Check to be sure a wire is not getting pinched and shorted when putting it in gear.
Old Dec 29, 2017 | 04:59 AM
x1
Old Dec 29, 2017 | 08:26 AM
bvolks's Avatar
I had the same problem with my '86 Bayou and it was the gas cap vent. I was able to blow it out with compressed air and had no more problems.
Bernhard
Oct 6, 2017 01:18 PM
stonfre
May 24, 2014 08:06 AM
flyinscrammy
Oct 24, 2013 12:07 PM
Beastly 3hundo
Aug 16, 2009 04:07 PM
