2000 arctic cat 300 4x4
Old Mar 25, 2018 | 11:40 AM
Stealth434's Avatar
Default 2000 arctic cat 300 4x4
Have had this atv for 2 years using for yard work. One day started smoking bad and lost conpressiin adjusted valves and had compression and lost again. Its was at 25 psi so i decided to do piston rings. Took it apart turns out bore was bad so bored .20 over. New pistion and rings and reinstalled everything according to the manual i have and i have only 70 compression checked over everything 2 twice still same result. But i adjusted valves out to me too loose and got 150 compression. I know valves aint suppose ti be this loose but idk where i went wring or mayb out of time still but maybe some can help. Thanks
Old Mar 25, 2018 | 03:09 PM
Kymco 450i's Avatar
If the engine is that worn the cam might be also, sounds likw a severly worn cam from what I am reading
Old Mar 25, 2018 | 09:23 PM
Stealth434's Avatar
I am stuck been messing with it for a while now i can fixed every atv that comes in my garage but this one bout to replace the head and cam but they dont remanufacture them
300forlife
Sep 23, 2000 03:54 PM
tinmandown
Mar 30, 2000 11:20 PM
BONER
Nov 11, 1999 08:45 AM
