04 90 sportsman won't start.
Old May 31, 2018 | 05:08 PM
Adnoh0420's Avatar
Default 04 90 sportsman won't start.
Cleaned carb, new fuel filter, new spark plug, new coil. It has spark, and when I take spark plug out it is wet. Did a compression check and it is at 90, from what I read, min. is 115. Is this right? Thanks is advance.
Old May 31, 2018 | 11:32 PM
Volkom's Avatar
Are you sure the plug is good? Just because it's new doesn't mean it's good. Similarly, just because it has spark doesn't mean it's enough. Do you have a spark tester?
Old Jun 1, 2018 | 07:18 AM
LT80's Avatar
LT80 Expert
They will run at 90.
Wet plug, I wonder if it's flooding.
Empty the carb. Apply full throttle and try to start. Once it starts sputtering and running, turn the fuel on.
martyMusto
Nov 26, 2008 10:31 PM
Dudenhymer
Aug 2, 2008 04:15 PM
