2007 Kawasake Bayou 250 voltage regulator
Old Aug 13, 2018 | 12:48 PM
Zshadd's Avatar
Default 2007 Kawasake Bayou 250 voltage regulator
My atv was cutting out while giving it throttle. I unplugged my voltage regulator and now it runs like a top. I was getting wrong readings at battery with ohm meter which is what prompted me to check regulator. Carb, stator, spark plug, coils are all good. Is this normal? I haven't found anything that would have voltage regulator causing this issue but it has resolved my issues.....Anyone else out there had the same problem?
Old Aug 14, 2018 | 02:00 AM
Yes, not with a 250 but had a KLF300 which ran rough and blew bulbs due to overcharging, and Honda 450s nearly always cut out dead if the regulator goes wrong. Also had a Honda 300 that blew two CDIs due to a faulty regulator. In theory, AC ignition systems should be totally separate from the charging circuit, but most modern ignition systems seem to be a combination of AC and DC.
Old Aug 14, 2018 | 06:10 AM
Zshadd's Avatar
Thanks for the info, I feel better knowing someone else has experienced the same thing. Replaced the volt reg and she runs great....
Glh
Jun 24, 2018 01:34 AM
dudemo
3) General Discussions..
Jun 20, 2018 03:30 AM
R. Brown
Jun 4, 2018 10:49 PM
ChiefGunny
Jun 6, 2017 01:34 AM
millerboy
Dec 3, 2005 06:27 AM
