95 425 magnum crazy electrical issues
Old Apr 16, 2019 | 04:44 PM
Jdn's Avatar
Jdn
Default 95 425 magnum crazy electrical issues
Hey folks, I have an odd problem with my 425. The engine dies when I apply an electrical load. For instance, connecting the battery when the machine is running. Or, with the battery disconnected and engine running, if I apply power to the cooling fan the engine will die. Sometimes it will just start missing on a very regular rhythm at an idle, and then kills when I apply power. About the only way it runs is with no electrical load applied, and the battery disconnected. The battery is new, and shows 13.4 volts.
I'm at a loss here. I picked up the machine over the winter. It would run occasionally, then didn't. I did a compression test and only had 45 psi, with the decompression unit removed from the camshaft. So I decided to break it down and did. New rings, valves, camshaft...Also, at idle, the + cable to the battery is showing 10 volts, and jumps up to 13.5 worth a little throttle. (This is with the batter disconnected)
Now it runs, but I'm really perplexed by this electrical thing. Any ideas? Thanks.
steelhead101
Nov 4, 2020 03:22 PM
4bratsdad
Oct 1, 2014 04:29 PM
CaptainQuint
Jan 13, 2007 06:15 AM
Faded
Dec 4, 2003 07:06 AM
fourlix
May 17, 2000 07:00 PM
