not getting enough starting power
Old Jul 18, 2019 | 07:22 PM
TonyCan's Avatar
Default not getting enough starting power
I have a 125 jeep gokart and i bought a factory charged sealed battery because i have had the worst luck with the small DIY type batteries. Anyhow, the kart has never been up to par, but it provides a few hours of fun at a time. SO i put the new battery in and when i try and crank it it starts to turn over and will fire up for a minute but dies, after a few times of trying to start it seems like the battery is losing power, but i put the meter to it and its still charged (11.4V) so i let is sit for a while and then try and crank it, again it turns over but wont start and then it starts again like the battery does not have enough juice even tho the multi meter says it does. I imagine its a relay or something, but i am kind of new to this. I have changed the starter, but that is about it. Also when i do get it running it will run, but seems to lose power and then it gets power and then loses power, its not reliable, i cant drive it to work everyday, lol. Any ideas?
TIA
Old Jul 19, 2019 | 03:20 AM
Those little batteries won't turn the engine over for long before running out of "puff". Hard work makes the acid fizz and the bubbles prevent the acid touching the plates until the bubbles rise and pop. Your main problem seems to be the jeep is bad to start, concentrate on getting it to start instantly, and your battery problem will go away.
Old Jul 19, 2019 | 08:37 AM
Zrock's Avatar
Super Quad Patrol
11.4v your battery is dead and needs charging... Look up battery voltage chart... Like said above figure out your hard starting issue first and your battery issue will go away.. you seem to have a choke or fuel delivery issue or the carb has just never been properly set from new. I would keep your battery on a maintainer and im guessing your previous battery issue was not understanding battery and voltage. If your machine does not start within the first 5 seconds of hitting the starter then you have issues with fuel/choke/carb still. My first guess would be choke is not working properly
Old Jul 19, 2019 | 04:30 PM
TonyCan's Avatar
Thanks, i will charge the battery, i had no idea about what is considered a dead battery.
trog
Sep 12, 2005 06:36 AM
outwest
Where to Ride
Jun 4, 2005 10:32 AM
Mike330R
Dunes and Dune Machines
19
Jan 15, 2003 05:15 PM
ecorman1
Feb 16, 2001 05:08 PM
evhwg
Jan 9, 2001 01:53 PM
