Repaired Ignition Switch now Nothing!! HELP!
Desert 150cc ATV Quad
Cranks and Runs if I short solenoid.
Fuse is blown. but if I short the connection no dash lights come on or brakes lights.
Red toggle switch will kill the engine.
Key switch has no effect in any fashion.
Brake safety feature has no effect, if brake is not pressed quad will still crank and run off solenoid.
TIA
TIA
This all started after I fixed/cleaned the ignition switch contacts.
(Solved)
https://atvconnection.com/forums/chi...functions.html
(Solved)
I would think your switch has had it, you can check the circuits through the switch with a meter or the test lamp, if you know which wire goes to what, but I think a new switch will be needed.
Simon Miller
Dec 27, 2016 12:03 PM
boola1341
1) Engine problems..
Mar 10, 2010 11:19 PM
