Repaired Ignition Switch now Nothing!! HELP!
Old Nov 10, 2019 | 07:15 PM
dbtoutfit's Avatar
Default Repaired Ignition Switch now Nothing!! HELP!
Desert 150cc ATV Quad
Cranks and Runs if I short solenoid.
Fuse is blown. but if I short the connection no dash lights come on or brakes lights.
Red toggle switch will kill the engine.
Key switch has no effect in any fashion.
Brake safety feature has no effect, if brake is not pressed quad will still crank and run off solenoid.
TIA
Old Nov 14, 2019 | 09:14 AM
Zrock's Avatar
Super Quad Patrol
did you repair or replace ignition switch?
Brake safety is bypassed if you jump the solenoid
what fuse is blown?
Old Nov 15, 2019 | 10:13 AM
dbtoutfit's Avatar
This all started after I fixed/cleaned the ignition switch contacts.
(Solved)
https://atvconnection.com/forums/chi...functions.html
Old Nov 16, 2019 | 02:33 AM
I would think your switch has had it, you can check the circuits through the switch with a meter or the test lamp, if you know which wire goes to what, but I think a new switch will be needed.
Simon Miller
Dec 27, 2016 12:03 PM
sefh3
Jul 29, 2016 02:51 AM
desjardins2012
1) Engine problems..
Jun 1, 2012 10:14 AM
Matrixxdg
Oct 4, 2011 08:01 AM
boola1341
Mar 10, 2010 11:19 PM
