Throttle Cable has no tension
Old Jan 20, 2020 | 08:23 PM
fhorta's Avatar
Default Throttle Cable has no tension
Hello. Having some problems with 86cc loncin quad. There is no tension on the the throttle. When i give it gas, the throttle switch doesn't spring back. Noticed the needle doesn't have a c clip to hold the needle, but a spring like triangular shape deal. Maybe i got the order wrong in putting it back after some carb cleaining. Before i twist "bottle cap"" on there to the carburetor, there is tension. Once i install is when i loose tension. I ensure the groove is aligned so goes in smoothly. Thanks for any help.
Old Jan 21, 2020 | 03:04 AM
There is a big diameter spring which sits between the slide and the "bottle cap," this provides the tension for the cable, also a little hairpin spring on the handlebar lever inside the control box. Check the cable isn't fraying where it goes through the "bottle cap".
Old Jan 21, 2020 | 09:06 AM
fhorta's Avatar
Both springs are there and springing. Will check cable not fraying. Thanks
ddesens
Feb 1, 2010 07:08 AM
TJ700
Mar 9, 2007 06:43 AM
Scatterbrain
Sep 15, 2005 10:40 PM
warrior8301
Feb 25, 2004 07:28 PM
