Wilderness trail 250 vin prefix LAPS
Old Jan 24, 2020 | 06:52 AM
Bk1985's Avatar
Default Wilderness trail 250 vin prefix LAPS
Has anyone ever had to replace key switch for wilderness trail lost key awhile back so had to bust the lock a year later and the wires came out from the back of the switch i tried to hot wire it but no luck the starter button works headlights come on but no spark i dont know what to do there isnt much info on this model amd all the parts seem to be discontinued i have the Manuel for it with all the part numbers and such but still no luck NEED HELP PLEASE THE SWITCH I NEED IS A 4 WIRE WITH ROUND YELLOW CONNECTOR
This is the type of switch i need i ordered this one for 71$ hopfully it work any help would be nice
Old Jan 25, 2020 | 03:18 AM
If the round plug is impossible to get, use a four wire switch made for a different model and cut and join the wires. Put the wiring diagram up on here if you have it, as there are a couple of different ways switches are wired.
Old Jan 25, 2020 | 08:00 AM
Bk1985's Avatar
Default Merryman
Ive tried putting a different switch on there im not sure if i have messed up somthing else when hooking up the new 4 wire key switch i have lights and electric start button works just no spark idk whats going on with it im loosing my patience with it i havent been able to find the correct diagrams for the wilderness trail 250 vin prefix LAPS is there a way to hot wire it or bypass the key switch on this model
Old Jan 26, 2020 | 03:01 AM
from the last photo, the original switch had black/white, brown, black and one other coming from it, check first, but if black is earth, try connecting black to black/white and see if you get a spark. If you don't, try with these wires disconnected.
Jrp79
Jul 21, 2023 05:16 AM
DJBRAVO
Aug 18, 2005 01:47 AM
howdy2u
Jul 11, 2005 12:26 AM
jfboy
Sep 27, 2001 05:01 AM
rydes400ex
Dec 26, 2000 08:13 PM
