02 Honda recon 250 carb issues.
Old Mar 20, 2020 | 11:35 AM
Cliff91's Avatar
Default 02 Honda recon 250 carb issues.
Got a new carb, throttle cable, and choke because poor idle. I installed everything and having problems getting idle right and gas is leaking into breather box. Any information would be greatly appreciated!!
Old Mar 20, 2020 | 12:33 PM
Kymco 450i's Avatar
OEM carb or aftermarket? Usually better off to rebuild oem carb with a quality kit so all needed specs can be set. Aftermarket carbs are setup for many different engines so additional adjusting/jetting is usually needed. The problem is you dont know what you have to start with!
Old Mar 21, 2020 | 03:06 AM
Overflow pipe from bottom of float bowl must dangle down, if you are getting fuel in the airbox, it must be routed upwards or blocked, and the float needle is stuck as well. Route that pipe down. Turn fuel tap off, run engine until it stalls, turn fuel on and check if fuel starts to run out of the overflow pipe again. If it does, you need to remove the float bowl and clean float needle and seat.
That 250 slide carb is dog rough compared to the CD carbs fitted to other Honda utility Quads. It always gives a splashy idle, and the difference between cold and hot means it idles way too slow cold, or way too fast hot. All you can do is find the happiest compromise.
Old Mar 22, 2020 | 07:13 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Vatt and cleaned and install repair kit in OEM carb.
Craigcoop
Jan 12, 2019 08:59 PM
pappyjerry
Sep 5, 2011 07:29 PM
ReconBayou
Jan 4, 2005 11:01 PM
Bobnkater
Apr 8, 2003 07:07 AM
