LT80 - Help! I've had enough with it...
Old May 19, 2020 | 11:19 AM
afeddy05's Avatar
Default LT80 - Help! I've had enough with it...
We have an LT80 that I recently rebuilt with help from a mechanic. Cleaned the carb, blocked off the oil injector pump, and running 32:1 pre-mix. I've adjusted the throttle needle to multiple positions and still have no luck.
It tries to start up quickly but then will stall right out. When I did have it running it would stall only at full throttle and at full throttle it would begin to backfire.
It does have a fuel shut off in the fuel line.
I am out of ideas at this point...
Old May 20, 2020 | 08:21 AM
LT80's Avatar
LT80 Expert
So it runs but just doesn't like full throttle?
What was re-built? top end? If so, did you get one of the cheap kits?
Backfiring is not common.
Old May 20, 2020 | 08:28 AM
afeddy05's Avatar
This weekend it would run, but stall and sometimes backfire at full throttle. However, Monday when my son tried to start it and keep it running it would start right up then stall out.
It was a Pro-X top end rebuild.
To back up and provide a full history...we've owned this for about a year. I did not know about the oil injection so that tank was run dry and what ruined the previous piston, hence the required re-build. This is also why I decided to go with a pre-mix from here forward.
Old May 20, 2020 | 08:47 PM
LT80's Avatar
LT80 Expert
Bad reed?
Plugged pipe?
Both good possibility's.
The bottom end survived the "no oil" episode without new main bearings?
Old May 21, 2020 | 06:42 AM
afeddy05's Avatar
What pipe would be plugged?
What is considered the "back end"?
Old May 21, 2020 | 07:46 AM
LT80's Avatar
LT80 Expert
The exhaust pipe.
Back end? What's up that you ask that?
Old May 21, 2020 | 07:50 AM
afeddy05's Avatar
LT80 for some reason I can't see your reply on here, but I can see it in my email.
So the exhaust pipe could be plugged? It is pushing air and smoke out.
Old May 22, 2020 | 07:46 PM
LT80's Avatar
LT80 Expert
It could be. It happens.
What about the reed?
hsv_buff
Aug 31, 2021 08:22 AM
flinn101
Mar 26, 2014 09:20 PM
charlieboy
Dec 29, 2010 12:10 PM
Dazzy
Aug 24, 2010 10:41 PM
