Lt80 wont take throttle.
Hi, my name is Dazzy and i am new to this site, I would like some help as my lt80 wont take throttle and it just seems to bogg down when i give it throttle, any info would be great. Thanks, Dazzy
Ok, right i took the atv out for a run in the feilds and it seemed to be running fine for around about half an hour until it started to conk out again when i hit over over halfway on the throttle so i took it back and now im not sure what to do because i've cleaned the carb and it still conking out, any help, Thanks Dazzy.
"run in the feilds"... I clean the carbs on my buddies kids LT80's alot. They ride in a field behind his house. I couldn't believe the stuff that got in the carb and airbox.
What most don't realize is that the dirt comes in the vent. I feel that you should clean the carb again to make sure it just didn't get more dirt in it.
If it's clean, I'd do a compression check.
What do you mean when you say 'a compression check' im only a teenager so im not sure what you mean
Hi LT80 thanks for all of your advice so far, I asked my dad what a compression check is so now i know but he is wondering about 'boiling the carb' . He has heard about people saying to boil the carb and i was wanting to know more about and you know alot about atv's. I was also hoping you could tell me what the proper procedure is for cleaning the carb as i have attempted to clean it but not sure if i done it correctly though, thanks Dazzy.
