30 psi compression. Valves or rings?
Old May 26, 2020 | 04:09 PM
cjben's Avatar
Default 30 psi compression. Valves or rings?
1999 bayou 220. Died won't start. Has spark, air and fuel. Only has 30 psi compression. How do I detrtmine if it's the rings or valves? Wasn't using oil or smoking before it died. It was making kind of a top end rattling noise for awhile before it quit.
Old May 28, 2020 | 02:53 AM
You would need a leak down tester, basically blow compressed air in through plug hole, and listen for air leaking out through exhaust and carb, if it isn't leaking there it must be head gasket or rings, probably hear that too, but who cares? Re set valve clearances and, if that doesn't fix it, the head has to come off, so check the valve seats, gasket, bore and rings and you will find the problem that way.
kawiman64
Mar 2, 2019 12:20 PM
slimmer455
Jul 18, 2017 07:42 PM
D.Vanhorn
Nov 30, 2009 04:46 PM
TRAILBLAZER07
Mar 14, 2007 02:29 AM
mlsmls
Jan 23, 2001 09:32 PM
