Please help
Old Jun 1, 2020 | 09:29 AM
Eddie Summitt's Avatar
Default Please help
Hello, I have a 03 Suzuki Ozark quadrunner 250. I'm hoping somebody can give me a little insight or advice on what to do. I got the bike from a friend who is no longer around the bike runs good rides good no problems there and when the motor works right and it's perfect. However the problem that I have found andtand isiis is I keep tearing up idler gears and starters. I have bought a OEM parts and when I put them on I can use the electric start roughly 30 times and then all of a sudden the starter starts grinding like it's not lined up with the gears which in turn tears up the idler gear. I have replaced both things about three times within a two-month time frame getting expensive and kind of a little bit annoying. I'm hoping somebody can give me a little bit of insight or what it could possibly be or even if it's an issue with these bikes. I know the idler gear is getting really hard to find for this particular bike. I don't really know what to do abouttabout this. Thanks for any information anyone can provide.
Old Jun 3, 2020 | 04:49 AM
Interesting that Suzuki changed the part number on the idler gear, may be worth checking that you don't have a miss match of parts, if it has had a later engine fitted and you are putting in early gears;- There must be some reason that early and late gears are different.
Eddie Summitt
Jun 9, 2020 02:51 PM
Gagallagher04401
Feb 16, 2016 05:54 AM
DODGE57HEMI
May 12, 2010 10:31 AM
DirtyCowboy
Sep 29, 2007 04:42 PM
Mrneg9
Jul 13, 2005 12:02 PM
