99 scrambler 400 2stroke
Old Apr 26, 2021 | 07:30 PM
Just and idjyut's Avatar
Default 99 scrambler 400 2stroke
Bit of a long one here i blew my dads quad up about 10 years ago. He sent the motor out to be rebored and new sleeve and piston. Got everything back put it all together got it running then parked it in a barn for id say about 5+ years i went to him and got him to sell me it cheap i hated seeing it sit there. I got it to start that day everything is full i shut it down somewhat quick cause i could tell it was running very lean more than likely need to tear carb apart and clean out but with everything apart i took off the oil pump line and made it turn over for a while to ensure oil is getting into it and it is giving me a little splurt of oil every like 5 seconds or so is this correct??? Also would it be a good idea since it sat so long to also add a weak oil mix to the first gas tank or so to help along side the oil pump to lube the engine back up since these bikes are dry aside from what you get from the oil pump? And what mix should i run in the tank?
Old May 9, 2021 | 07:45 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it would not hurt to run premix at like 40 to 1 mix. you shouldn't even try to start it it its been sitting that long before a good carb cleaning and maybe even a small amount of 2 stroke oil down into the cyl. to help lube it where it's a new rebuild. just my .02
shakes1977
Feb 5, 2012 06:18 AM
Scrambler40096
Mar 12, 2011 10:13 PM
agoodman
May 7, 2007 02:45 PM
Eaglecollector
Jan 10, 2005 04:21 AM
eman4000
Jun 6, 2002 10:43 PM
