Kawasaki mojave 250 radiator fan won't turn on
Old Jul 13, 2022 | 07:08 PM
KawasakiRider767's Avatar
Default Kawasaki mojave 250 radiator fan won't turn on
I have a 1993 mojave 250 and I can't get the radiator fan to run. I was running a switch so I can turn the fan on and off whenever I want but it won't work. The fan only works when given external power from a battery. I tried jumping the thermostat wires and still nothing. I used a multimeter and it gets voltage but when I check the power cable that connects to the ignition coil I get nothing. I checked when it was both running and off. I know the machine gets power because the front lights work. I checked all the wiring and it seems fine I even went through the trouble shooting steps in the manual and still no luck.
Old Jul 14, 2022 | 01:50 AM
Don't know that model at all. Put the wiring diagram from the manual up on here. Though if you just want a switched set up, why not a wire from ignition switched positive to an on/off switch and onwards to the fan motor, by-passing the original set up.
Old Jul 16, 2022 | 01:30 AM
I didn't think of that I will try doing it this weekend
Old Jul 17, 2022 | 02:13 AM
Wow! never seen that before, the fan has its own dedicated stator coil and rectifier, may be worth checking the rest of the alternator is working properly, and that the fan motor is 12v as, from the diagram, they could have made it any voltage they wanted to. In fact, voltage will have varied with engine revs, but they would set max voltage at one the fan motor can cope with.
Old Aug 3, 2022 | 12:19 AM
I tired by passing it and all that did was fry my ignition coil and I had to buy a new one. But when doing it I got spark when touching it to the fan but it wouldn't turn on. The only way I've been able to get it to turn on is with direct power from a battery
Belinda Kaye McIntyre Tyra
Mar 31, 2013 09:43 PM
ElectricShift
Jun 4, 2005 11:51 PM
ranger696f
Jan 18, 2005 02:04 AM
DAFUZZ
Mar 28, 2004 11:28 AM
tom18801
Oct 3, 2002 12:27 PM
