needing help on 50cc coolster
Old May 7, 2023 | 10:42 AM
Red14091's Avatar
Default needing help on 50cc coolster
I was gifted a 50cc coolster3050B I found bad pin in one snap block, so found bad CDI, as well as possibly coil ordered a set to repair. I am having trouble trying to get light to work, no power at switch, I have one loose snap block with a Blue Green and white wire that I can see was plugged into something but I have no extra blocks to connect it too. Help!! Been trying to find a real schematic to do wiring but can't find only generic and some of the wiring fo a 125cc. That blue green whit block does appear to be in headlight circuit of harness but can't see where it goes too. I am thinking the former owner maybe lost a part working on it. LMK thanks red
Old May 7, 2023 | 08:21 PM
djshad1469's Avatar
It sounds like someone may have already installed an aftermarket wiring harness which usually comes with two of the 3 pin connectors with blue, green and white wires. If you only have one headlight the second connector wouldn't be used.
Old May 8, 2023 | 03:24 AM
Quite a lot of Chinese Kids Quads have AC lights driven directly by the alternator. So, if it is, and you haven't had it started, the lights won't light up.
Jason Dueitt
1) Engine problems..
Oct 8, 2018 07:58 PM
FaTaL_ErR0r
May 18, 2017 08:55 AM
HAYABUSARIDER
Nov 9, 2011 11:28 PM
bronco2v8
Jun 8, 2006 02:36 AM
Mrneg9
Aug 19, 2005 03:36 PM
