Belt Flop SP 500
Old May 3, 2001 | 10:03 PM
Sportsman44's Avatar
My 2000 SP has 520 miles on it. It started making a rattling noise at the end of my last ride. The noise is worst at about 3000 RPM when there is not much load on the belt. I took the belt cover off and ran it in neutral. At around 3000 RPM the belt flops up and down on the topside alot. Does this mean my belt has a flat spot? I turned the rear pulley backwards and watched the belt on the pulley. It rides about 1/8" above the pulley for about one-half round then 1/4" above the pulley the other one-half. Any suggestions, I'm new too belt drives?
Old May 3, 2001 | 11:01 PM
JRC702's Avatar
That belt is HISTORY!!!!
Does your 2000 have the lifetime belt warranty like the 2001's? If not should not be expensive to fix.
Old May 3, 2001 | 11:06 PM
snowdowg's Avatar
yeppers your belt is done. i have had the same trouble with mine it has gone through 2 belts in 500 miles. but the dealer i bought it from has been good to me and did not charge me for the belts.
Old May 3, 2001 | 11:21 PM
No lifetime belt warranty. They started that in 2001. Do you recommend only Polaris Belts?
Thanks for the help.
Old May 4, 2001 | 04:15 AM
Traildog's Avatar
Your belt should last longer than 500 miles? Are you using Lo range when going through mud and up hills etc. I have just changed my belt after 2000 miles and it was still OK and I ride quite aggressively.
Old May 4, 2001 | 07:56 AM
Yes, I use low range alot. Must have been a bad belt. Hope its not something wrong with on of the drive pulleys.
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
