Lt80 won’t start
Old Aug 28, 2023 | 11:00 AM
ducey995's Avatar
Default Lt80 won’t start
Hello I ah e a lot 80 it has good spark and fuel but won’t start it was running a little boggy but still running then let it big out and wouldn’t start again if anyone knows anything please let me know
Old Aug 29, 2023 | 02:46 AM
Clean the carb out, an engine needs the right fuel/air mix, it may be getting some fuel but not the right ratio for good running. If that doesn't fix it, check compression. When it gets below 90 psi, they get bad to start.
Old Aug 30, 2023 | 07:40 AM
ducey995's Avatar
I have just cleaned carb took plug out to check for spark has good spark but lot of petrol come out of head so think it’s flooded what best way to clear and will I need a new plug
Old Aug 31, 2023 | 03:34 AM
If you leave the tap on PRIme, fuel gets past the float needle and fills crankcase and cylinder with fuel. Only way I know of to get it out is spin the engine over on the starter with the plug out until it stops blowing fuel out. WARNING, I have set two LT80s on fire doing this, the coil must be disconnected to stop it sparking, even then, have something to smother a potential fire handy. Dry the plug before refitting and, no choke, throttle wide open, try to start it. If it doesn't fire up fairly quickly, it will have "wet the plug" so will need the plug drying again, and remember, never leave the tap on prime.
Vciferni
Jun 9, 2018 06:54 PM
putman0911
Jan 23, 2012 08:16 PM
karl88
Jul 25, 2011 05:22 PM
CRF-Ridaz07
Aug 21, 2007 01:40 AM
yfz450bb07
May 17, 2004 03:44 PM
