Lakota start issue
Old Apr 18, 2024 | 11:48 AM
Newtsy's Avatar
Default Lakota start issue
We have a 96 lakota that won't start with the ignition switch. It WILL start by the solenoid.
Replaced new:
Ignition switch
Neutral sensor
Starter Circuit relay
CDI box
Rectifier
Carburetor
Spark plug
Checked:
Neutral sensor pin/spring
gear shifter
Battery
Wires
Starter
Solenoid
Fuses
Has spark.
We are at wits end with this thing. Can anyone suggest a solution? We have tried every suggestion we could find.
Old Apr 19, 2024 | 02:58 AM
Usual suspect is the start button, once you have checked the solenoid. Don't throw parts at a problem, test circuits. The starter circuit will have lock-outs, don't know the Lakota but KLF300 has an extra solenoid, you can hear it click in when you switch ignition on in neutral.
Casey Lynch
Aug 18, 2021 02:00 PM
Patrick Voss
Oct 26, 2020 03:04 AM
Cassandra Mitchell
Apr 23, 2018 05:28 PM
Lakota300276
Jun 7, 2007 09:26 PM
lakotasportrida
Jul 24, 2003 04:54 PM
