Chinese 250cc no spark
Old Apr 26, 2024 | 03:36 PM
Nedelec2493's Avatar
Default Chinese 250cc no spark
Hello I recently bought a Chinese 250cc with a GN300 it had spark when I bought it and go figure brought it home to clean the carb and now I have no spark (tested by connecting spark plug to the block) it is a DC system which I have power at both prongs of my ignition coil and even have battery power at my spark plug. Where do I go from here ? Also is there a magic pin I can remove to confirm it’s not a kill switch messing me up kinda like the ac cdi pin.
Old Apr 27, 2024 | 03:09 AM
There are two different DC systems, and a coil with two wires, one of which is live with ign on, would indicate you have a 1980s car style 12volt set up rather than DC CDI. The blue/white will probably be the trigger coil, some have two wires, some use earth for the return, the green/white would indicate it is probably a two wire trigger. Green is usually earth. Black/red is usually the pos feed from ign switch. Black/yellow, negative pulse from ignitor (black box) to ign coil. They don't need a kill wire, as switching the black/red off cuts the spark, as in a car. Test those wires to the ignitor, trigger wires will produce a small AC voltage when engine is spun, and usually about 400ohms resistance. Actual values are not that important but open circuit or no resistance is bad, check if touching black/yellow pin on coil to earth, with ignition on, induces a spark at the plug. If all tests out as OK, but no spark when the engine is spun, it has to be the ignitor at fault
Old Apr 27, 2024 | 11:41 AM
Perfect I’ll check it over once I’m back around the quad with the info you have posted merry. I’ll inform you of my findings on Monday, if that is the case any idea where I could find a igniter cdi like that one as it seems to be odd ball.
Old Apr 28, 2024 | 03:25 AM
KLF300 and Lakota Kawasakis used ignitors but different wiring colours, so you would have to be careful to wire it up right, plus ignition timing and advance curve could be a bit different. There were lots of Chinese replacement Lakota ignitors on eBay last time I looked.
Old Apr 29, 2024 | 11:49 AM
Default Update
So black yellow had battery voltage 12.5 constant
red black no DV voltage but put it to acv20 and had .15
green is ground and had continuity
green white I couldn’t get dc or ac voltage out of it
black white had .44 at acv20
When doing a continuity test found .208 ( will upload picture) still no spark at the moment
Old Apr 30, 2024 | 03:11 AM
Blue/white and green/white will probably be the trigger wires so you should get a small ac voltage pulse across them when engine is spun, can be as little as .4v can be 4v or more. The black/yellow 12v pos reading is strange as it is usually the one direct from ignitor to coil, providing the negative pulse to coil. Disconnect it from both coil and ignitor and see if it still has 12v pos with ign on. If it has, it must be the pos feed from ign switch. This would mean the black/red feeds the black white to the coil which doesn't make much sense. If black/yellow is now dead, check if black/red and black/white have 12v pos on them with ignition on, this would make more sense as it would indicate they are the positive wires.
Jav
Jul 21, 2023 09:11 AM
Jpeace
Jun 20, 2021 09:34 AM
Ricky Bennett
May 7, 2020 11:26 AM
Ryan Downey
Exotic and Modified Quads
Sep 29, 2015 09:31 AM
weasel85
Jul 1, 2009 05:35 AM
